TCS and Slip light coming on after some not so good feeling misfiring or shaking
Marshall206
Car: 2000 Infinity Q45
any ideas what it is, most likely traction control i guess but why the engine shake?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Check your MAF connection first.
Did you just have a minimum wage pit monkey change your oil filter from the top?
If you bother to search and read some of the previous posts here, most of your questions will have been answered several times before.
GThreat
Car: 1999 Q45t
I had the same problem a while back with my 1999 Q45. I could never figure out what was causing it, came and went. Then during the emission test required in my county I failed the gas cap test, it was leaking. I replaced the cap about a year ago now and the problem has completely disappeared!
I am still baffled by all this.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
I am sorry but I don't see any correlation between the gas cap and a missfire, At most the gas cap has to do with the emissions.
What else did you do thatmight have fixed the problem?
GThreat
Car: 1999 Q45t
I know that it makes no sense at all, but I put up with the problem for about 6 months trying to figure out what it could be. After I filled up with gas sometimes it went away for several weeks. The leaky gas cap theory fits the intermittent nature of the event, as sometimes when it was tightened it did not leak.
After a whole year now, and just the gas cap changed, nothing else, the problem has disappeared. Crazy crazy crazy.
Infinitiguy19
Perhaps it could have been the gasoline?
GThreat
Car: 1999 Q45t
Yes, the gasoline is certainly part of the problem and I am thinking maybe it is because most has 10% ethanol? I am using 93 octane.
The car has occasionally been missing, but has not thrown the Slip and TCS lights. I have been adding an octane booster and that has pretty well taken care of this problem.
Bad gas + leaky gas cap = problem?
ViruzOne
Car: 00 Q45 An.Ed.
BUMP
So any solid solutions to this problem? It seems a lot of members have similar symptoms but not similar solutions.
I have had that stumble and occasional missfire but it goes away on its own. Yesterday I got a more noticeable stumble that wouldnt go away and the TCS OFF and SLIP light on the dash. Also have a SES light which is more than likely a knock sensor code.
bullittandy
Car: 2003 Infiniti Q45 70K miles
1999 Infiniti Q45 Touring 180K miles
1997 Infiniti Q45 270K miles (sold)
1997 Infiniti Q45 186K miles (junk-sold)
Idle stumble is likely a bad coil. I relaced the ABS relay on my 97 when those lights came on but I'm not sure where its located on a 2000.
Check engine codes first and see what you get.
IceCubeFoSho
Car: 2000 Infiniti Q45 Anniversary Edition
This is EXACTLY what I'm getting right now!
I haven't cleaned the MAF, I get oil changes from the dealer, I use 93 Octane fuel, etc. I'm going to get the codes checked soon
miata007
Car: 2009 Cube 6sp, 2005 G35 sedan
It is most likely the coils.
I had the same issue with engine stumbling and occasion TCS light on. Replaced all coils and runs like a champ for 20,000 miles so far.
If your coils are 100k already, I suggest you replaced all of them.Save some $$$ and do it yourself. $500 for parts.
007
ViruzOne
Car: 00 Q45 An.Ed.
Took the Q into the shop today... Diagnosis: 2 failing coil packs.
I have a little money to burn so i decided to let my mechanic do the labor and really needed the car running ASAP so just decided to go with my local dealer for parts. Unfortunately they delivered the wrong coil packs! So guess it'll be til the morning.
Guess i should of changed ALL the coil packs with the spark plugs. Would of saved me some time and money!
MAX_POWERS
I had the same problem too. I replaced two coil packs, had primary ign. code. I don't know how both are related. I will be replacing all coil packs.
