TCS/ABS Trouble shooting issues - Need Help
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
was threw a code a # of months back for secondary throttle position sensor. That went away and was replaced by Righr Rear Wheel Sensor.Replaced both wheel sensors, then threw code for Left Rear wheel sensor.I Seperated my Left Rear sensor from old harness to combine w/ New Right Rear.Before i could do this went back to throwing code for Right Rear Sensor.Then this morning threw the code for secondary throttle position sensor.
HHHHHHHEEEEEEELLLLLLLLLPPPPPPPPP MMMEEEEEEE
WTF???
Modified by jamesmost at 9:48 AM 10/12/2006
Q45tech
Clean contacts on TCS/ABS ecu, if that doesn't stop it replace unit.......gives you time to find a spare from junkyard.
Just another of those modules you keep a spare for diagnosis.
jamesmost
BTY how does that plug come out of the ECU Just the 2 screws ??do i need to disconnect the battery first ??
jamesmost
Q45tech wrote:Clean contacts on TCS/ABS ecu, if that doesn't stop it replace unit.......gives you time to find a spare from junkyard.
ok cleaned contacts applied dilectric grease, still No good
BTY car does not do self check when initially back up any more. Also tcs will engage around 3000 rpm while power brakeing, but i can hang a turn punch it and fish tail w/ tires spinning and it will not engage.Have a used ecu on the way,
Modified by jamesmost at 5:21 PM 10/13/2006
