The module above the glovebox blinked out code 34. I thought that was the ABS control module at first, but page BR-103 of the service manual says it is the TCM (throttle control module?). 3 long blinks, 4 short blinks. On page BR-104 of the service manual, there is a code 34 in the chart which says "power supply circuit (for sensor)"VStar650CL wrote: ↑Tue Sep 03, 2024 1:48 pmThere's no code 34 on the ABS. It could be 3 and 4, but those both apply to the rear wheel actuator. You can find the code list on page BR-42 (PDF page 843), the wiring schematic on BR-45 (PDF 846), and the specific diagnostic procedure for 3 and 4 on BR-50 (PDF 851):
https://www.nicoclub.com/service-manual ... 2F1991.pdf
Alright thanks, I'll test that tomorrow after work. I am expecting the VSS to be okay, as it showed an accurate mph reading on the scan tool during a road test. Where else should I look? In another forum post with a similar issue they said to replace the two blue relays underneath the battery tray. Would that be worth a shot? I'm trying to avoid just throwing parts at it though of course.VStar650CL wrote: ↑Tue Sep 03, 2024 3:56 pmYep, that's for the TCM and not the ABS/TCS. The diagrams show the VSS signal being read by the cluster and then rebroadcast to both the transmission and ABS, so you probably have either a bad VSS or a bad cluster. The sensor is easy to check, it should produce an AC voltage with the wheels turning which increases with speed. The cluster should also be easy to check, looks like pin 34 on the cluster Y/PU should be the signal wire to the rest of the car. With the wheels turning it should show either a 2.5V signal or about half of battery voltage depending on the signal level, but it shouldn't read 0V or battery.
I don't have any issues with power steering.Q451990 wrote: ↑Wed Sep 04, 2024 10:33 amDoes power steering drop out when the speedometer isn't working properly? Here's a thread from long long ago that might help.
speed-sensor-not-the-answer-to-ps-loss-t299603.html
I tried testing the voltage from the speed sensor last night but there weren't any lifts open, so i just put it on jack stands and spun the rear wheels by hand. The highest reading I got was .2v, but it may have just not been spinning fast enough. I'll throw it up on the lift tonight after work and see if I can get a better reading while it is in drive.VStar650CL wrote: ↑Wed Sep 04, 2024 6:16 amI think first see if any of the codes will erase, it seems likely the the TCS code isn't related to the other two. Nissan ECU's have always had a weird habit of ceasing data transmission when they throw certain codes. That's why on modern ones you often get a C1130 plus an ABS/slip lamp along with a MIL, because the ECM stops sending an engine speed signal on CAN after it throws a code. I'm wondering if your VSS isn't cutting out intermittently and causing the cluster to stop sending a speed signal, and in turn that's causing the TCM to stop talking to the engine. I think I'd see if the voltage drops out at pin 27 on the TCM (see AT-38 and 39) whenever the speedometer acts up.
Okay that’s good to know about the memory codes. I did actually have my multimeter set to AC volts, but I’ll get a better reading later this evening.VStar650CL wrote: ↑Thu Sep 05, 2024 7:13 amChecking the sensor, you won't get much of a reading on DC volts because it's an AC signal. One leg may be grounded at the cluster, so the best check is to go across the sensor terminals with the sensor disconnected and your meter on AC volts. That way you're reading full wave instead of half wave and you'll get a better idea of whether it's stable or not. Nissan speedo sensors from that era are all magnet-amplified, and it's not uncommon for them to cut in and out when they're failing. So it may well be the VSS causing your issue and not the cluster.
I think the ECM is the only unit on the car which has a backup memory, so all the other codes should clear by doing a hard battery reset. If they come back it means the DTC condition still exists.
I haven't pulled any of the transmission codes. Is that what the "A/T check" procedure is that you can access on the screen on the bottom left of the cluster? I attempted to do that but it just said "OK" every time. The transmission malfunction warning came on about 20 minutes into my drive to work, but it stayed off during my drive home after work.
That's the one. In my experience, it'll hold the code until you run the test, then it clears the code.JackJ217 wrote: ↑Thu Sep 05, 2024 4:31 pm
Just tried it again with the original cluster and all of the interior connectors plugged back in and no luck. I’m stumped.VStar650CL wrote: ↑Thu Sep 05, 2024 5:56 pmYep, that sounds like a right diagnosis. The sensor hardware in those clusters has been known to fail. Often it's just bad solder or leaky capacitors, so you might want to pull it apart and retouch the connector pins, plus replace any electrolytic caps which are bulgy or leaking.
Where can I find the pinouts? I found the section about the cluster in the FSM that I accessed from the forum but the only information there is how to remove it. Would I have to find a manual for both model years?Q451990 wrote: ↑Tue Sep 10, 2024 2:32 pmUgg. That's the stuff that car guy nightmares are made of. In general, yellow plugs tend to be for ABS stuff, but I don't know for sure in this particular case. The best advice I can give is to compare the pin-outs in the factory service manual for each model, and see if you can figure out what happened. In my experience, smoke usually means ground and positive reversed somewhere.
