phats69 wrote:Since i have posted this the ABS TCS light is gone. Only the check engine light is still on. This happened to me the first time I changed a flat tire and put the spare on.
You've got a couple of threads going in this forum both talking about the same thing. You're getting conflicting answers since in your other thread you didn't mention installing a spare. Was it a full-size (same size) spare or the 50 mile trunk spare?
I have no experience with this issue other than what I've read here but I know that if you're riding around on tires that aren't the same diameter it will upset your ABS and traction control and all the time the TPS sensor is going crazy trying to compensate. Hence the source of the warning lights and CEL.
Get back on four tires all the same size and your ABS and TCS warning lights will go away. It sounds like this has already happened.
phats69 wrote:........and what do you think the check engine light is still on for??
Again, I have no experience on this one but I think the CEL will reset itself after so many miles or stops/starts. If not you will be able to clear them with a code reader unless you have a true problem with the TP sensor. Let us know what you find out.
