I've posted on this issue before, however I'll explain it again for anyone who didn't read it. My 94 240sx has this weird problem. Every once in a while, it won't shift between first and second gears (auto). It will sometimes stick and I can ease it until it finally does shift, but sometimes that doesn't work. If I restart the car, the problem goes away - until the next time, which could be a few hours later or a few minutes. Temperature doesn't seem to affect it. It also seems to shift hard sometimes but not all the time. I'm totally boggled. This problem occurred before and after a transmission rebuild. I replaced the TCM as advised by Nistech. I'm still having the same problem. Is this a common occurrence with S13s? The TCM was in a weird location and doesn't seem like something that would go bad or have problems. Is there any kind of bulletin from Nissan on the TCM? Could the problem be related to any other sensors or the ECU? I'm at a loss. I have to drive my car but I'm worried if I don't figure out this problem, I'm going to screw something up and need another rebuild. Any ideas? Anyone?
My Website
