elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Mon Jul 17, 2006 8:59 am
IM not sure if ive posted on this before (if I have, im sorry), but when my TC locks up in 4th gear and i give it a little bit of gas it slips... you feel it shudder through the entire car, it doesnt feel good...
Its been doing this for a while and it seems to be getting slightly worse, but it seems to be really bad when its hot out...
Trans fluid has been done... I recently dropped the pan, magnet had some stuff on it and there was a reasonable amount of clutch material in the screen. I know that my trans is on its way south, but is there anything that I can do to make it not get terribly worse... Ive already put everything else on hold until i figure out whats going on so i wont be screwed if i need to buy a new trans. My local shop does flushes for $89+tax which is a good deal..... Should I do the flush? I have a can of BG quick clean for AT's as well. Are there any additives that may help this condition...
Other than the above, the trans shifts reasonably well.
