TC rod bolts...
BomexS13
Car: '89 Nissan 240SX
'00 Toyota Celica
OMG, it looks like you need the power of zeus to take the bolts out. Any special tool I need to use besides my broken arm:help
catty
Car: '92 240sx
I installed my new TC rods today but used an impact wrench to take em off, you could always try using a huge breaker bar, even though there isn't much room to use one.
mandoz85
I just soaked the bolts in pb blaster and then used a big breaker bar they came off with no problem.
MarkEmark
Car: fully-built '95 240sx KA-T
Yah, I had no problem taking mine off using a torque-wrench.
Guess I'm just strong. :pface
It will, however, make your shoulders kinda sore (this is after doing the tension rod brackets too, and installing/reinstalling the tension rods twice).
IvoryJ30t
Car: 95 Maxima GLE, 95 Maxima GXE
oh my god, please tell me you didnt use the torque wrench to remove the bolts???
BIG NO-NO!!
MarkEmark
Are you kidding me?
What else would you suggest? It's a freakin' bolt. A socket on one end, a wrench on another.
Maybe I'm thinking about something else--I'm talking about the tension rods--which I assume are the same thing as t/c rods--although I dont know why people call them t/c rods...
You use a torque wrench to remove bolts that are torqued tightly--such as lug nuts. Ergo, I used it to remove the tension rod bolts. I encountered no problems whatsoever. Nuts came off easily, nuts went on easily. And then, when installing the bolts, the torque wrench conveniently has torque settings that "click" when you tighten them to the desired torque. Now you tell me how you can get around using a torque wrench for tightening them.
I'd like to hear your reasoning as to why it's wrong to use a torque wrench to remove a bolt with an open ended wrench on the other end.
I'm confused... help me out here.... :confused:
yeswepromise
no.you use a breaker bar to remove bolts.
Touchdown038
Car: Computers, cars, sports
You can, but there's nothing wrong with using a torque wrench to take off bolts. I do it all the time, hell, my 1/2 inch torque wrench is built like a breaker bar.
MarkEmark
Touchdown038 wrote:You can, but there's nothing wrong with using a torque wrench to take off bolts. I do it all the time, hell, my 1/2 inch torque wrench is built like a breaker bar.
Yah, I don't get it...it's not like the torque wrench is set at anything when I'm removing it--it's in its "neutral" position. The one I used is a wicked heavy duty craftsmen wrench---and my dad--who I consider a lot more knowledgeable than a lot of people on this forum--has used the torque wrench plenty of times to loosen bolts when I've been workin on my car or his with him...and he/I have never had a problem.
kandyflip445
Car: My gurl and my car
If you use it to take of bolts it throws off the calibration.
sxseguy
Car: Makin' it go faster!
I broke one 19mm socket and then a socket wrench trying to get mine off using a 2.5' breaker bar after soaking them with lube. Tough little buggers.
BomexS13
'00 Toyota Celica
i have to pay SEARS a visit tomorrow...
180fan
Car: 89 fastback
lol aw yeah, lifetime warranty on craftsman tools stick it to em good!
MarkEmark
kandyflip445 wrote:If you use it to take of bolts it throws off the calibration.
Has this happened to you or is this just hear-say? HOW does it throw off the calibration? I want some evidence...
I have two torque wrenches--one I almost never use--so its calibration can be considered "perfect," and the one I use to loosen bolts is just as accurate as the one I never use.
BomexS13
'00 Toyota Celica
MarkEmark wrote:Has this happened to you or is this just hear-say? HOW does it throw off the calibration? I want some evidence...
Are your tools craftsman also? Just curious...
MarkEmark
Most of my tools are craftsman and I've NEVER had a problem with them--most of them except for those that become victim to the tool-troll...and those are replaced by what I can find the quickest and the cheapest, because it's usually in the middle of a project that I need the "LOST" tool....
IvoryJ30t
right now my 3/8 and 1/2 inch torque wrenches are the craftsman digitork [the one with the numbers in the window]. i took one apart to see how it works, [then returned it for a new one] and i can see why they say not to use torque wrenches for a breaker bar.
if you wind the wrench up to the top of the scale, and it does not click while your using it improperly, it will do no harm.
if you click it and contine to apply force, the metal seat at the other end of the ratchet [in the shaft] can be knocked off center, miscalibrating it.
also, using it in that manner can just add excess wear to your precision instrument.
MarkEmark
IvoryJ30t wrote:right now my 3/8 and 1/2 inch torque wrenches are the craftsman digitork [the one with the numbers in the window]. i took one apart to see how it works, [then returned it for a new one] and i can see why they say not to use torque wrenches for a breaker bar.
What if it's in its "neutral" position at the bottom of the scale and there is no clicking? (which is how I loosen bolts with it)?
IvoryJ30t
unless you have a different style entirely, its is also bad to turn the wrench below its lowest setting.
ive never had a wrench that has a "park" setting at the bottom of the scale.
MarkEmark
IvoryJ30t wrote:unless you have a different style entirely, its is also bad to turn the wrench below its lowest setting.
I didn't say "park," you jerk, I said "neutral!" :icesangel
I guess it's not below its lowest setting then--probably just at the lowest setting. Anyway--enough post-whoring for me
IvoryJ30t
then maybe its ok if you put the wrench in "drive"
i figure if the manufacturer says not to do something, its probably a good idea if you pay attention. jerk. :pface
