elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Wed Nov 08, 2006 5:04 pm
The VH uses a 90mm TB... I really dont see how adding a larger TB on a naturally aspirated, stockish car would provide much HP... Not sure how big the TB on the maxima is, but if your mating a 90mm TB to a 70mm hole, I dont really see the point? the air is still going through 70mm...
If your TB is smaller than the hole on the plenum itd be fine, or if you created a new plenum with a bigger opening to match the plenum, thatd be good too... not sure how much that would even do, but certainly would allow more possibilities...
