TB Coolant Mod!!
Silent Drifter
Car: '93 Nissan hatch
'90 Nissan coupe
'96 Ford Ranger
Looking for a bike!
I was messing around with my engine today an noticed that the TB has coolant running through it. So I decided to reroute the line so that is bypasses the throttle body an goes into the return line. I havent heard of any other 240 doing this, I know Spec V owners have done this because it eliminates hot coolant running through the trottle body an they say its stays alot cooler. I seriously doubt theres any big gain from this but it should keep air temps down which cant hurt. I was wondering though this shouldnt hurt anything because since I havent heard of any other 240 doing this I was wondering if it might disrupt something. Enjoy!
EnzoRWD
Car: 1997 Volvo 850 T5
might be a cold climate thing. but nm that wont make sense, coolant is cold each morning too. hmm. let me know what the deal is, im cleaning up the engine bay, and thats another thing that can go-Enzo
deviousKA
Car: 90 240sx NA /72 Datsun 510 NA /86 corolla GTS NA
tb coolant lines are to eliminate frosting of the throttle body in cold driving conditions on most cars. I dont know if this is why nissan implemented it or not. I dont see much downside to trying it unless you live in a cold climate and your throttle gets stuck
Silent Drifter
'90 Nissan coupe
'96 Ford Ranger
Looking for a bike!
well I live in florida so im not really worried bout that. But it shold bring down air temps some.
nightwalker
Car: 240sx
I have this done too. cheap easy mod, I don't know how much it helps, but every little bit helps.
knightrider
Car: black 90 240 coupe
yea its mostly a cold climate thing to keep your TB from freezing, but if you live in florida or SoCali its not really needed
Nismoking
How do you reroute, and would it be bad for somewhere in VA? We get snow, but I'm sure I can make this a spring, summer, early fall mod lol!
ThanksChris
Silent Drifter
'90 Nissan coupe
'96 Ford Ranger
Looking for a bike!
just look at ur throttle body an ull see the coolant lines an just take on line an run it back into the return line. Its too hard to explain but its quite self explainatory when you look at it. I really dont see why it would hurt in va because cold airs better an way i think its just to keep your throttle body from frosting. It takes like 5min so you could try it when its cold an if it doesnt hurt anything leave it an if it does just wait till it warms up.
MikeMurphy
Car: Guess
Cold air is better but you cant have your throttle plate sticking open now can you. And for the split second the air is in the TB its not going to heat up much anyhow.
Scott McLellan
The frost on the throttle blades is only at startup. After the engine warms up it should be fine. I am looking at a Car Craft magazine right now that says that this simple mod on an LT1 V8 is worth 3-5 hp. By the way, does anyone know where you can get a lower temp themostat for a KA?Thanks, Scotty
E Dogg
Car: 1997 M3 sedan
1988 TII RX-7 10th AE
1990 Ford Bronco XLT
any of u guys have a pic of this? i have my intake off now and i noticed some lines are attached to the plenum too and i was wondering if i could just hook up a t fitting instead....
Silent Drifter
'90 Nissan coupe
'96 Ford Ranger
Looking for a bike!
youll see 2 lines going into the throttle body all you have to do is disconnect both of them an remove one of the rubber hoses all together than use the one thats left to connect to where you removed that hose.
E Dogg
Car: 1997 M3 sedan
oh, i got those already, im talking about the ones attached to the intame manifold plenum. i drew up a sketch; forgive my primitive methods my dig camera is AWOL
Silent Drifter
'90 Nissan coupe
'96 Ford Ranger
Looking for a bike!
O I have no Idea about those, But it seems like they could be removed. I wouldnt know but the motor Im puttin in my car Ive removed all emmisions ps/ac alot of uneccesary vaccuum lines an cleans up the engine bay quite nicely. Im sure it will have a rough idle but it doesnt bother me.
Nathan
I think your thinking of the IACV E Dogg, that is DEFINITELY something you dont want to remove.
Silent Drifter
'90 Nissan coupe
'96 Ford Ranger
Looking for a bike!
yea make sure you what your removing befor you remove it.
