ken in az »
https://forums.nicoclub.com/ken-in-az-u105959.html
Fri Jan 16, 2009 9:39 am
OK - just free mods but I think it helped cause I definitely feel a little kick in the pants. Pics to come this weekend.
1st mod was the airbox*. I replaced the air filter when I just purchased my car about a month or so ago and I noticed all kinds of crap in the airbox. Leaves, sand, dirt, feathers, and other random organic material. That just made me sick (thank you ocd) and I had to remove the assembly to completely to clean it. When I removed it I noticed that the airbox is actually 3 peices, the hood duct that you can see going to the front grill, the actual airbox where the MAF plugs into, and a separate balloon looking peice that bolts to the fender but fits to the airbox via another vent type hole just like the grill duct peice. I pulled it out which was a pain, dumped all the leaves and crap out of it, and decided to just keep it out because it did absolutely nothing except maybe muffle the intake sound to tame the engine noise. This now gives the airbox 2 holes to source air from and to my reasoning this would allow more airflow. To those that think I'm loosing a RAM AIR effect from the front duct I can dispell that reasoning because there is no way the grill ducting seals enough to allow for any type of pressure to build in the box.
With this mod the engine intake noise is only slightly higher but it also sounds good - while not being annoying. Seriously adding only a tenth of a decible.
- why didn't I just buy an INJEN intake? - For starters I don't like oiled air filters. Say what you will, but I will never use and oiled air filter again. On my silverado it came with an AirRaid filer setup when I bought it and it allways required premium 91 fuel because of a detonation problem and it had a hard start problem. I thought because it probably had a programmer on it making these problems more apparent. My first oil change and air filter cleaning everything goes well, I didn't over oil the filter and I let it dry out in the AZ desert heat all day before driving. Well the detonation problem got worse and the hard start turned into a really hard start problem. I diagnosed everything from fuel pressure - timing - manifold leaks - all sorts of stuff with no avail. I finally put in 100 oct racing fuel and it still detonated with the temps outside at 60* F I knew something was wrong. So my last resort before taking it to a shop for diagnosing was to clean the MAF. I took it out and it was dirty as all H - E - double toothpicks. Cleaned it thoroughly and reinstalled it and now - all problems disappeared!
I will only ever use Amsoil Dry filter technology from here on out for performance.
2nd mod is the Throttle Body Coolant Bypass** - I noticed this super easy mod when I was changing the engine belts. The throttle body has 2 coolant lines connected to it from the top and the bottom. These line allow coolant to run through the throttly body and back into the main cooling system. The purpose of this line is to heat the TB plate and surrounding area to prevent icing of the throttle plate and having the throttle stick open when not desired. Unfortunately this line also heats the incoming air which makes it less dense and thus makes less power. I acheived the bypass with an approx. 8" - 10" of 5/16" coolant hose and routed it around the TB instead of through it. This connects the 2 ends and gets the TB out of the coolong system. I reused the factory coolant hose clamps to retain the factory look.
With this mod I did not notice anything until I drove it for a while. I honestly thought I lost power initially but after 2 days of driving I really notice it now. The engine is more responsive, has more torque in the lower end, and is generally more fun to drive I doubt it gave much hp in the higher rpm range but I could be wrong.
I wish I had some sort of Dyno or Gtech to document any changes, sadly I only have the trusty BUTT Dyno software which can only be taken with a grain of salt.
These are free except the coolant hose, which was $1 per foot at autozone, the guy forgot to write down the sku number so when I bought all the other stuff he just threw it in there and said happy holidays - so technically I did get it for free.
Keep and eye out in the coming months as I attempt to manufacture my first performance poduct. I will attempt to produce a bolt in performance air box that will utilize the stock ducting from the front grill and also a new duct that will pull from the bottom of the car that will utilize an oversize amsoil dry air filter and a removable plexiglass top to help with air filer replacement. This will completely replace the stock airbox and intake hose. It will still fit under the engine covers and look almost factory. I have no idea on pricing but I hope for it to be competative with the INJEN unit but be far more appealing cosmetically and make more power. I'm at a time in my life where my bank account can support my knowledge of performance and manufacturing to compliment my and others vehicles. If it is not cost effective then it will only be available in limited runs.
Also keep an eye out for phenolic intake manifold spacers. these are commonly used to isolate engine heat from the aluminum intake manifold as to provide a cooled, more dense air charge. These have been proven in other applications to reduce underhood heat and increase in hp/tq by approx 5-7hp and 5-7tq. This is accomplished two fold - heat removal and lengthening of the intake runner.
Disclamers -* Perform this mod at your own risk**Perform this mod at your own risk as this mod could cause you TB to freeze and cause serious damage to you, your engine, and others around you. I am in no way responsible for any damages that occur as a consequense of the mod.
Thanks and Happy Holidays!
Ken
