okay so thats a whew!!! i was about to go crazy, i will update more stuff....this what i got so far
stock flywheel (im going to resurface)
pressure plate with used clutch (thinkin bout buying new one)
both pedals, but clutch pedal missing sensor
stick shift
5speed transmission/w 5 speed dust plate
cluth clyinder w/hardline and sof line w/slave
5 speed cross member (ordering ne transmission mount for it)
throw out bearing? i dunno know the technical name but it hooks up to the trans
parts i need!!!
driveshaft (i learned i need to find out if i have abs or not, and i dont know if i should get new or used??)
bolts (one bolt is missing on the shifter plate that cover the pivot?? and bell housing bolts unless i can use the auto ones???)
manual ecu (heard i can auto ecu, unless if its a pain in the *** i would buy a ecu)
if anybody selling these holla at me
[email protected] im in hawaii 96853
if anyone see that im missing sumthing please help me out!!
