New 1995 Taurus E-Fan.
The left side was slightly trimmed and the top center tab was removed.
The bottom of the fan had a large gap that needed to be closed up.
I used some malleable plastic that I cut to size and heated to roughly the countour of the fan shroud and then rivetted into place.
Inside view of shroud plastic cover.
Aluminum radiator modification.
The two top bungs would be used to hold the upper part of the fan in place.
Two more aluminum bungs were added to the lower part of the radiator.
As well, the larger bung for the Audi Thermosensor was added.
Mounting the fan to the radiator.
New 1990 Audi 2 Speed Radiator Thermosensor with custom aluminum bung.
Low Speed ON - 167F (75C)
Low Speed OFF - 158F (70C)
High Speed ON - 180F (82C)
High Speed OFF - 170F (77C)
Hollister Road Fan Relay Kit
http://www.hollisterroad.com/proddetail ... d=MarkVIII
Modified Hollister Road Fan Relay Kit
Substituted the 8ga main battery feed wire for 4ga multi-strand cable
Various relay wires cut to length and covered with cable protectors.
Top left is an inline 7.5A fuse for the relays connected to an available ignition switched 12V source to ensure fan will only come on when the ignition is on.
Metrapac 630 connector kit used for fan main power feed (on the right).
Two Ground connections (to the left) for fan and for thermosensor.
Mian 50A slow-blo fuse (bottom left).
Fan power feed (with Metrapac connector) lines marked for High speed, Low Speed and ground.
Audi Thermosensor Connector purchased from local VW audi shop.
After install.
From the top.
Heaps of clearance.
From the bottom looking up.
From the bottom again.
From the bottom looking at the thermosensor.
http://forums.corral.net/forums/general ... -amps.html
Before E-Fan conversion.
After Taurus E-fan conversion.
Testing the Audi Thermosensor
http://www.youtube.com/watch?v=cOuNreEindQ
Testing complete Taurus E-Fan system
http://www.youtube.com/watch?v=fmj-h8ZE3-o
Testing confirmed that the low speed thermosensor on-off trigger thresholds are not consistant with advertised thresholds. I attribute that to mounting the thermosensor on the lower portion of the end tank as opposed to the upper most portion where the coolant coming in from the engine would be hotter. Basically, the distance between the oem coolant temp sensor and the Audi thermosensor is creating the variance in triggering thresholds observed.
The results so far look promising and I`ll reserve final judgement til after a road test.
