that picture is the reason i even started this. so so so clean.gregfarz78 wrote:I stripped all the tar crap out of mine b/c its not really sound deadener and also to make sure there was no rust hiding under it. After I got everything stripped down I painted with rust bullet and applied new sound deadener. $15-20 of dry ice makes fast work of that tar
i don't know what your smoking but i said TAR not TAN. nice try thoughectomorph wrote:hey so i have tan interior also and i was just curious what kind of paint did you use? i think i'll do the same during my break. sorry i'm no help.
sorry i didnt clarify...i'm going to put everything back in. carpet and everything when im doneS13Teddy wrote:Stripped interior WITH sound deadening is FAIL.
If you're going to strip out the car, you need to go all the way.
the reason poeple even do it, is to save weight, If your just putting everything back in there, you wont even notice the benifit of removine the tar. you would be defeating the purpose of doing so.s13importuner7 wrote:sorry i didnt clarify...i'm going to put everything back in. carpet and everything when im done
what kind of sound deadener is that?gregfarz78 wrote:
I'm sorry, I don't see the point of what you're doing. Why are you going to remove the tar if you're going to put the interior back in? That's just a waste of time.s13importuner7 wrote:sorry i didnt clarify...i'm going to put everything back in. carpet and everything when im done
i love your build thread. i wish 240's were like that from the factorygregfarz78 wrote:I stripped all the tar crap out of mine b/c its not really sound deadener and also to make sure there was no rust hiding under it. After I got everything stripped down I painted with rust bullet and applied new sound deadener. $15-20 of dry ice makes fast work of that tar
Not really I acutally found some surface rust under that tar crap, not all of us are lucky enough to live in a hot dry climate And why put sound deadener on top of the tar and add more weight, remove it then sound deaden and its about an even exchangeS13Teddy wrote:
