Tapping noise...
S14 Wannabe
Car: Zeni S14
My friend has a problem with his '98 240sx SE.There is a hard clicking noise coming from around the fuel rail of the KA24DE. We can't tell if it's from the crankcase or the valves. What my friend does believe is that the stock injectors are messing up. When a stock injector is clogged does it make a click sound? A week ago the car was missing badly in what seemed to be bad spark plug wire but the "missing" went away. He has a set of S14 SR20DET injectors. Should we plug those in to see if that takes away the problem? Or should we try Seafoam for the car and see if it takes it away? Or are we totally wrong in our assumptions of the fuel injectors and it's something else.
Any help would be greatly appreciated.
s13sr20chris
all nissan injectors are really loud. however if your prob is abnormally loud then i would pull the valve cover and look around for broken stuff.
Nismo_Freak
Car: 89 Nissan 240SX
Sounds like a stuck injector that is trying to open... they get louder when they do that.
You also might want to check the lash on the intake side camshaft as incorrect lash makes a loud noise as well.
s13sr20chris
yeah that
912.0turbo
Whose car are you talking about Dorian?
Nismo_Freak
Drive it to Austin hehe, I'll fix er up.
S14 Wannabe
Car: Zeni S14
912.0turbo wrote:Whose car are you talking about Dorian?
Chae's '97. LOL thanks Nismo_Freak. We tried the other SR injectors. Holy hell did that thing run rich but it didn't solve the tapping noise. He said he has the calculations for the valve lash, but he said something about him figuring it out.
Side Note : Nismo_Freak, I could always use someone to trust/recommend our cars to. Hell I love Austin especially drinking in Austin. LOL. It's closer than some of my friends in Houston that speacialize in Nissan's. When I get my car back I'd love to take a trip up there to check out Silviawerks. :ylsuper
912.0turbo
Ill go!!!
s13sr20chris
hmmmm, valve lash adjustment. also known as "fun with kent-moore fancy shmancy special tools". i dont envy you bro.
all kidding aside, its not that bad. just tedious.
