torranceandy »
https://forums.nicoclub.com/torranceandy-u132369.html
Fri Apr 24, 2009 10:00 am
2007 G35 Sedan
If anyone happens to experience a tapping noise on cold startup and can't figure out what it could be, here is a possible cause (it happened to me).
On cold startup there was this tapping noise (I started hearing it after my first 7500 miles) that changed in speed according to engin RPM. You know... the kind that sounds like a valve is adjusted way too loose. The engine ran normally. Once the engine was almost fully warmed up the noise would go away and not come back until the engine had time to completely cool down (and I mean COMPLETELY) so morning startups were a total bummer. After a trip to the dealer and two weeks of waiting (I had a G35 loaner so it wasn't so bad) they informed me the car was done and that the problem was a broken valve spring. From what the dealer tech told me, this is really rare (first time he'd seen it on any VQ35 motor.
Modified by torranceandy at 3:35 PM 4/24/2009
