sm1nts2escape wrote:I just bought another 240sx 93 ka24de dohc and finnally got it running.I have ran it for about 2 hours total now.122,000 mile on the engine.Anyways there is a tapping sound comming from the front of the engine right near the oil plug but it does not sound like the ussual chain noise.Witch to me sounds like a loose bycycle chain.This tapping noise is inconsistent though.It has the same sound as a tapping valve but like I said it is inconsistent.All of the valve tapping engines I have heard in the past had a consistent tap loud or quiet.The tapping is mainly in the low rpms around 1 grand but still makes the noise in the higher rpms.It mainly taps the loudest when the revs are falling.I am thinking about checking the valve lash but it would be alot easier to check the timing chain.All help is appreciated.Thanks
The tapping noise comes from the upper and lower timing chain guides.I myself have just removed the upper guide hoping that it would remove the tapping noise since it is so irretating to listen to at red lights. The upper guide isn't really needed, so I just removed it, it had major wear and tear on it whan I removed it. Engine still makes the tapping noise which means the lower guides need to go as well. Total to remove the upper guide is in under 1 hour. To remove the lower guides add another 4 hours to that, and some new guides. To take your time and do it right is what it will take to open it up and fix the situation. Make shure that you have all new gaskets ready to go unless you plan to wait for some gasket maker to set up.
