Tapping into Parking light wiring
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
wrightdog26
Car: 2004 Infiniti G35 sedan
Which color wires do I need to tap into? Can't make out the wiring diagram for some sequential led strips I want to install. TIA
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Power wires for park and tail are all Red/Blue, ground is Black or Black/White depending which fixture you tap. Wiring diagram starts on LT-143 here:
https://www.nicoclub.com/service-manual ... 4%2Flt.pdf
wrightdog26
I looked and saw 'R/L'. Does L stand for some sort of shade of blue, like say lavender?
VStar650CL
Technical Expert
No, L is Blue because B is used for Black. If you look on GI-17 here, there's a list of color abbreviations along with general instructions for reading a Nissan WD:
https://www.nicoclub.com/service-manual ... 4%2Fgi.pdf
wrightdog26
Thanks, well appreciated! Plan to put on sequential led strips.
GTWSNL
Car: 2023 Nissan Pathfinder
Hello, can you confirm the tail light wire colors for running light turn signal in reverse light on driver passenger as I’m trying to type into for my LED tail gate light bar
VStar650CL
Technical Expert
On a '23 Pathy, LH combination lamp is Park=Pink, Turn=Gray, Stop=Light Green. RH is Park=Violet, Turn=Sky Blue, Stop=Green. Backup lamps are separate sockets and are both Light Green. Note that the colors are for the car harness. Subassembly harnesses for Nissan lamps have colors determined by the part vendor and aren't usually specified in the FSM.
Return to “G35 and G37 Interior, Exterior and Audio”
