I am completely confused and frustrated with my issue and I'm dying for some help.
First here's a little background.
I recently installed the OPT7 Aura Smart-Color LED Strip Interior Lighting Kit in my 2008 Altima Coupe. The LED kit also has a "door assist feature" aux wire that can be used to tap into a sensor so that the LEDs light up white when the doors open and return to its original state when the doors close. After a lot of research, I figured out how to tap into the dome light and activate my LEDs when the doors open. Many people say it's an easy mod and they all seemed pretty successful with it.
Here's what I did:
1. Connected the OPT7 LED Kit control box to a constant power fuse. LEDs work perfectly and footwell is beautiful. Next is the door assist feature.
2. Opened up A-Pillar on driver's side and located dome light wires.
The white/red wire is the positive lead and the white wire with two silver bars is the negative lead. (Just an example picture. I didn't actually cut out that section)
3. Spliced two new wires to the dome light wires using those blue splice lock connectors and ran the two new wires under the dash near the fuse box for easy access. Then I spliced the two new wires (I'll refer to them as the dome light wires as well) with the OPT7 door assist aux wires.
4. Moment of truth. I spliced the dome light wires to the OPT7 door assist aux wires and tested the doors. The LEDs lit up white as they were supposed to when the doors opened and returned to the original state when doors closed. Everything was working as expected.
5. Next, I started to install a SPDT relay to control the power source of the OPT7 LED Kit control box. The reason being is if my OPT7 LED Kit control box is always hooked up to a constant power fuse, it's going to draw from the battery whether the car is on or off, but at the same time it always needs to be on for the door assist feature to work. So, the purpose of the SPDT relay is give the OPT7 LED kit control box power from the constant power fuse when it receives a signal from the dome lights (opened doors). Otherwise, the OPT7 LED kit control box only receives power from the ignition fuse (doors closed). That way, if the car is off the LEDs are only powered when the doors are opened. This solves the power source issue for the LEDs and the door assist feature.
If this helps, this is how I hooked up the relay.
Terminal 85: Ground
Terminal 86: Dome Light +
Terminal 30 (COM): OPT& Aura LED Control Box +
Terminal 87 (NO): Constant Power Fuse
Terminal 87a (NC): Ignition Fuse
Now, this is where things go south. After I install the relay, the moment I connect the dome light wire (+) to the SPDT relay terminal 86 (the trigger terminal), the relay is instantly switched on and the LEDs turn white. I'm immediately confused because both my doors are closed and the dome lights weren't triggered. I tested it for quite awhile to no avail. The dome lights were triggering my relay despite them being off and doors closed. After 2 afternoons of testing and frustration, I gave up and decided to just use the door assist feature without the relay (as I originally did at the beginning).
I removed the SPDT relay and just spliced the door assist aux wires directly as it had worked before. The moment the wires met, the LEDs turned white and I got the same problem as I did with the relay: the dome lights were triggering my door assist feature as soon as the wires met (doors closed and dome lights not triggered). I tested it again for some time but also no luck. At this point, I'm just depressed after spending two days trying to get this door assist feature to work. I just don't understand why the door assist feature worked in the very beginning (only worked once) and now it doesn't.
For the most part, I know I connected everything correctly. However, it seems like the dome light wires have a current going through them even know they aren't triggered? Just a guess.
Anyone have any ideas, suggestions, or experience with this? Any help is appreciated!
TDLR:
Dome lights trigger my footwell LEDs even though dome lights are off and doors are closed.
