Tapping after GB4 cam swap
nvrplzd240
Car: 04 G35, 02 CBR600 f4i, 90 Sentra
I recently swapped cams in my 1990 Nissan 240sx to Gabe's GB4 cam. She runs/drives fine, but around 2200rpm tapping occurs within the head. I originally thought it was the lash adjusters so I took them apart and cleaned them/reassembled them. When they were apart I noticed marks on the bottom of the rocker arms indicating contact with the top of the valve spring. My thinking is the tapping is coming from this contact. It only occurs on the exhaust side. I had the cam towers milled .025 as called for but never double checked the machine shops work before I put everything back together. I was just wondering if you guys could shed any light upon my situation.
neverlift
its not just the lifters bleeding off air?
btw long time no talk man!she running good other then above?
nvrplzd240
neverlift wrote:its not just the lifters bleeding off air?
Yeah man it's been a while.. It's crazy I've been so busy with work and school
Everything's great other than that..
I really dont think its the lifters bleeding off air.. unless they sound like metal tapping together loudly. That, and there is no clearance between the rocker arms and the top of the valve springs when the valves are closed
neverlift
did you pull the v/c and check with your fingers for them to be stiff,if you can collapse a rocker(with a finger) then that one has air,and needs to bleed off.
All I know is the first time I heard lifter noise I almost shat myself,thinking my motor was gone.
nvrplzd240
neverlift wrote:did you pull the v/c and check with your fingers for them to be stiff,if you can collapse a rocker(with a finger) then that one has air,and needs to bleed off.
They're stiff as ever
nvrplzd240
nevermind... i can't hear the tapping anymore
the freshly spun rod bearing's making too much noise
neverlift
man
what weight you using? go x~40 or 50 weight, I had some knock(5 times now fvcking ka) and just top off with some heavy weight, it clears up. FOR ME. Man I hate to see good folks have problems like this when some of these guys could use a problem or two to learn from... end rant !
sorry to here this shiz man.
nvrplzd240
I'm done wit this **** bro
I mean its ghey as fizzuck. To have a spun rod bearing on a 52mile engine.
I was going to buy some coils, so I'm taking that money and adding to it for a few more weeks to get an engine.
I'm gonna drop a CA in her and never look back
neverlift
yeah I here good about the ca... are you serious tho?
I hate to see you let this thing go,but a ca will always make your go mojo happy,unlike the ka,a lot of dispare comes with ka builds it seems... I'm gonna keep my fingers crossed tho. Good luck with the ca(175ish stock is good starting place anyways)
what you gonna do with the ka? part out to fund new ca? dibs on header! or something damn it seriously email me so we can talk...
StorminNorman
Car: s14
I had the same problem. detonated on the third piston.Between the timming being off a little and shaving the head and bigger cams ishould have known to redo the bottom to support this but live and learn.sorry to hear about you luck, detonating a motor is never fun
nvrplzd240
neverlift wrote:yeah I here good about the ca... are you serious tho?
Yeah bro I'm serious
I sent ya an email earlier today
Jackask89nissan
how do you bleed the lifters i got a 90' 240sx and it sat for 2 years be i got it now the lifters are noisy as F#ck how do i bleed the lifters?srry for back tracking but i would really like to know
