ceniack »
https://forums.nicoclub.com/ceniack-u14675.html
Wed Apr 12, 2006 10:41 am
i used the revhard with a .63 a/r tangental housing, i had to make some custom motor mounts though to clock the engine about an inch towards the passanger side. i took some grade 8 all thread and then took 5 hockey pucks, drilled holes though the center of them, and made me a couple studs to thread though them. used 2 hockey pucks on the passanger side and 3 on the driver side, so the motor sits about half an inch lower on the passanger side and about half an inch higher on the driver side. drive train and everything worked out. ended up costing me about 30 bucks total (the all thread was expensive, the hockey pucks were like 2 dollars each)
