Tanabe Suspension Components for your S13/S14!! **In Stock**
Look here for specials on Nissan parts, accessories or modifications, or tell our sponsors what you are looking for!
VividRacing.com
Car: 1990 240sx W/ Redtop sr20det
Tanabe Sustec Sway Bars - Corner flatter and faster with Tanabe's specially designed larger diameter sway bars. Engineered for precise fitment. Experience increased roll resistance and cornering stability without the compromise of ride comfort. http://www.vividracing.com/cat..._8=15
Tanabe Front Sway Bar 30.4mm 89-94 Nissan 240SX/Tanabe Front Sway Bar 30.4mm 95-98 Nissan 240SX
Tanabe Rear Sway Bar 22.0mm 89-94 Nissan 240SX/Tanabe Rear Sway Bar 27.5mm 95-98 Nissan 240SX
We are currently running these on my buddies 89 Coupe and it improved the handling of his car 10X. I would definitly recommend these sway bars to anyone out there running the stock sways still.
Tanabe Drift Spec Sustec Pillow Tension Rod S13/S14
Tanabe Drift Spec Sustec Pillow Toe Rod S13/S14
Tanabe Two Point Sustec Under Brace S13/S14
Sustec Under Brace connects the vehicle's lower arms for increased rigidity while reducing chassis flex under cornering loads. Engineered using a "Double I-beam" design for lightweight construction and increased structural rigidity
Tanabe Drift Spec Sustec Pillow Camber Arm 95-98 240SX S14-Tanabe camber arms were designed to correct or add camber adjustment beyond the factory arm specifications.
Tanabe Front Aluminum Strut Bar S13/S14
-Tanabe Sustec Strut Bar - Whenever driving aggressively, a vehicle's suspension can only work just a hard as the stiffness of the chassis permits. Increase the rigidity of the vehicle's frame resulting in improved, predictable handling.
LOTS IN STOCK!!
Return to “Advertisers' Marketplace!”
