tanabe springs
blindsnyper
Car: 2007 versa
how difficult is it to install the tanabe lowering springs.
does anybody have a tutorial, pics, instructions?
jfanaselle
Car: 2007 Nissan Versa Hatchback SL, 2008 Nissan Rogue SL
Well I can't speak for the Versa specifically, but when you change springs out on a car it's relatively simple. You just need to put the car on jack-stands and remove the wheels. Then you need to remove the strut assembly which is done by unbolting it from the bottom and the top (The bottom usually bolts right to your hub assembly and the top will have bolts under the hood or under the plastic panels in the cargo area).
Once the strut is off of the car, you need to use a spring compressor to squeeze down the spring so you can remove it. A spring compressor is a small set of clamps that you use with a drill or wrench - you can rent them at your local auto parts store for very cheap (I think I used some from Autozone and it was actually free, just had to leave a deposit for them).
Then you simply compress the new spring, re-install it on the strut and mount the strut back to the vehicle. Do this four times and you're done!
I've seen others on this forum mention that it only took an hour or so to install their springs. The only real issue I've ever heard of anyone running into is that they can't remove all of the bolts under the hood and they need to heat them up with a torch before they'll loosen up.
bulld0g
Car: 2007 Nissan Versa SL "Bulld0g Edition"
took me about 15 minutes for the rear and about a hour for the front.....a spring compressor is your friend
KimberKenobi
Car: the Camel
EV wrote:The front is standard McPherson struts. You'd need some spring compressors... and an air compressor and pneumatic impact wrench would help GREATLY. With those, probably a couple hours. Without... could take most of the day.
bulld0g
here is a pic of the type of spring compressor I used....
