versa2nr »
https://forums.nicoclub.com/versa2nr-u65681.html
Sat Jul 21, 2007 6:37 am
Okay, so I got home after work last night and I broke apart the strut tower on the passenger side. It seems that the rubber that you guys are referring to was actually integrated into the stock spring to eliminate the clunk noise I was hearing. It looked like the top of the spring was dipped in liquid silicone or something to coat it. The Tanabe springs dont have this coating at the top or the bottom. When the drop spring is on the car there is about 1/8" of rotational play on the spring itself. So when the wheels are turned in either direction the spring will bind in place to a certain point and then will eventually let go causing the spring to rotate in the bearing at the top and cause the clunk noise. It doesn't look like this would cause any damage or anything and it is definitley louder inside the car than out. Just more of an irritation I guess. I guess when I have more time to mess with it, I will get a rubber filler of some sort fabbed up to eliminate the noise. I will let you know what I find.
