I just ordered Tanabe GF210 springs for my S13. I was happy with them when i had my S14 but on these the spring rates are totaly different. 2.9kg/mm in front and 2.7kg/mm in the rear.
On the S14 version the spring rate is higher in the rear than in the front. Won't this S13 setup create more understeer? All the springs i saw had higher spring rates in the front so i didn't have much choice since i cant afford coilovers.
I'm going for a cheap drift setup, could the higher front spring rate on these be a problem? Has anyone used these on their S13?
Thanks
