Products: Tanabe Front/Rear Sustec Strut BarsOrdered From: Performance Nissan Parts,
http://www.performancenissanparts.com Total Price Shipped: $196Overall Score: 8.5 / 10 I finally received the strut bars yesterday after UPS took their sweet time delivery it. When I was deciding between either the Tanabe or GReedy the deciding factor was that GReedy sucks at delivery times to it's vendors. I had waited over two weeks before canceling {different shop} and ordering the Tanabe which were shipped three days after {from Performance Nissan Parts}. Another problem at that time was that I could not find ANY pictures of the Tanabe strut bars. The provided factor picture only showed what seems to be the rear but I was not able to tell that at that current time. Well I have tons of pictures for you people thinking about buying along with a short review. Product: Is overall well done and extremely clean. The strut bar itself looks slick with a dark red bar and Tanabe printed upon it and overall shows quality. Both strut bars feel light. A weak point I found on the strut, along with most of the lower priced strut bars is the connection bolts which allow the bar to move. You could weld this but I decided that currently that was not needed. Install: Front -------------The front was very easy to install as you could imagine. Instruction were printed neatly describing cautions of the product. However step by step install directions were not included for those who might need them. There is also a good amount of room between the strut bar and the engine block. Rear-------------The rear instructions are all in Japanese and thus I could not read anything. This sucks since there are three pages of instructions and cautions I could not read. The install itself was a challenge. Having already taken out the rear speakers and the rear dash from when I installed the Tanabe GF210 springs two weeks earlier the process was quicker though. I first started by taking apart the strut bar and bolting down the strut plates. This was the first challenge since one of the bolts which is closest to the seats is near impossible to reach because the strut plates blocks it. To solve this I removed the "rubber liner" around the entrance to the trunk (all doing this from the inside of the car), and loosed the trunk carpet so I could stick a hand in from the side and with my other hand and a long extension slowing lower the bolt into the hole and with the hand through the side slowly screw on the bolt. It took me a couple times but I eventually got it. I then used a ruler to measure the length from the speaker holes and carefully proceeded to cut a hole in the rear dash using a knife. Once the holes were good, overall cutting them to fit was a middle difficult experience, I installed the rear dash back. Put back the speakers back on and proceeded to install the bar. This was the easy part and once this was done it was complete. Overall the thing looks very sick. Space wise there is also a good gap between the bar and the speakers as you can see in Picture # 4. The holes themselves are by far not cut perfect however I plan on going to Home Depot and picking something to cover them up.
==============================UPDATE: I went today and they did not have anything so I stopped by Auto Zone and picked up what appears to be some thick rubber gasket liner.
{ O } { O } < looks like that. I just cut it in half and cut out the center circles and it fits perfect. The holes are now NOT visible.============================== Does it make a difference: To be honest I only noticed a small difference but still a difference! Appearance wise it does look good but performance wise I still can't decide. Perhaps getting adjustable tension rods is a better choice for the cash for some. Turning ability is much improved and losing traction (burnout) in the rear is also much easier.
Overall the strut bars are good and recommened. A score of 8 / 10 is awarded.
Modified by Bosrudorfer at 9:17 PM 1/6/2006
