talon injectors
ca18detsilvia
i have some 440cc talon turbo injectors that my friend has that i can get for cheap, the are topfeed, but will they work fine w/ teh ca
CA18 RS13
Car: non-fwd japanese sports cars
talon uses low impendance injectors, so no.
controler
I have some 440's from a MkIII supra. Now, I have 2 sets, one from 87, the other from 90, I think they were changed from low impedence from high impedence, but I am not sure. Anyway which will work?
looksLikeA240
Car: break dancing
your mom will work!!! haha jk robert:cool:
1fast200
Car: too many to list
My CA18DET injectors are LOW IMPEDANCE (2-3 Ohm)
Thank you.
Movingviolation240
Car: '95 Nissan 240SX 400hp SR20DET -SOLD
'93 Lexus SC300 w/ SP66 turbo kit
the DSM injectors should work, havn't looked at them but from what I've heard from freinds they would drop right in.
They are like 465cc right? (at least that's what 1st gens were if I remember right).
later,
Paul
ca18detsilvia
one of you said they wont work cuz they are low impetence, and another said his are low impetence. so will they work or not, if now which ones should i get, also, i herd that you can use an SR chutch in a ca aslong as you have an SR flywheel, is this correct
CA18 RS13
im hearing conflicting reports as well. all along ive been hearing that they are high impendence, yet if i search the database it says they are indeed 2-3 Ohms, yet people are still using the high impendance TII injectors as a drop in. i need to know this for certain since i just bought a set of high impendance tII injectors, and id like to have a definative answer if these work without a dropping resistor before i try them out and fry my ecu.
*edit* ok after some searching you can use high or low impendence injectors on a low impendance system, but supposidly the low impendance are prefered. but you cannot use low impendance injectors on a high impendance system or you will fry the ecu. since the CA18DET uses a low impendance system either should work.
Boostn
I put my Talon's injectors up on ebay if anyone's interested.
http://cgi.ebay.ca/ws/eBayISAP...&rd=1
Talon injectors are 450cc and 2-3 ohm resistance.
