TonyJohn »
https://forums.nicoclub.com/tonyjohn-u166399.html
Wed Aug 18, 2010 3:20 pm
One thing that constantly bugs me (the other is the grill, as I"m sure you've seen from my other posts) about my Rogue is the large wheel wells that make even the SL's 17" wheels look too small.
I've found keeping the wheel wells nice and black with tire shine does help a lot. One real solution is getting shorter springs to lower the car - I believe Eddnog did that, and it looks awesome. Another option would be larger wheels. But I'm too cheap for both of those.
So I've been thinking, how would taller (larger diameter) tires looks? That is if they'd even fit on the vehicle. Has anyone tried or thought of this?
Hello gpsmoucer...Just my two cents...
The gap in the wheel wells of the Rogue (really any SUV) is necessary for the proper wheel travel when the vehicle goes over bumps, etc. and is really part of the design by the engineers. As such, it's not really something to be "fixed" and shouldn't bug you.
I agree, it may not be visually attractive, but if you lower the Rogue to relieve your annoyance with the gap, you run the risk of damage to the wheel wells and/or the tires from bottoming out due to potholes, etc. Not to mention the comfort of the ride will likely suffer. And the suspension geometry will probably be affected as well, unless you're really careful on how you lower it.
Of course, if you install shocks (or struts, or whatever is appropriate) that are so stiff that no bottoming is possible, the gap will be closed, but the ride will definitely suffer!
My suggestion is you should carefully weigh the importance of the gap vs. ride comfort and possible premature suspension wear-and-tear.
