Talk aobut beating a dead horse....(SR20DE)
PantherRacer
Car: 1992 Nissan Skyline R32 RB20DET Sedan
Well, this was one of my questions from back when I started on Nico. not very much closer to an answer, and I've been searching for years. I'll get to the point.
SR20DE in Silvia Q's. Is it safe to turbo it? I vaugely remember someone saying something about either pistons or the cylinder walls not standing up to boost pressure on the DE. is this bs?
The transverse SR has been turbo'd without major modification..it's just sticking the parts on and making provisions for oil to run & be provided.
basically I want to know, if I take parts from an DET (mani, dp, turbo, injectors (fuel pump/pressure regulator) will I be able to put these on the DE and not run into problems? if so, what all will I need to take? would I need to sleeve the cylinders, get rods & pistons also?
or would I be straight following the transverse SR turboing guide (obviously taking note of the differences.)
spider_slayer
Car: S14 240SX
S13 240SX
i think nismo created a post a while back detailing a build up of a sr20de. if i remember you need to use det pistons and rods. i'd try searching for it
Nismo_Freak
Car: 89 Nissan 240SX
You can get about 300whp out of them relatively safely, but it depends on the type of DE.
The S13 engines lend to be better due to the lower CR. You can bolt on the OEM DET equipment and it will work fine.
The only things you will need to fabricate will be the oil and coolant lines to the turbo. Everything else is good to go besides the obvious tuning work.
PantherRacer
Edit: So if I get an S14 Silvia Q's I'd have to watch the CR?
Nismo_Freak
PantherRacer wrote:Edit: So if I get an S14 Silvia Q's I'd have to watch the CR?
You'd just have to keep the boost down.
PantherRacer
Nismo_Freak wrote:You'd just have to keep the boost down.
awwwwwwwwwwww that's no fun ...............so, I wouldn't be able to say, beat slightly modded DET's unless I got either DET pistons or lower compression pistons designed for the DET? though I would be able to keep up?
MagikDragon
Car: 1991 240SX, 1992 240SX, 1986 MB 190E 2.3-16
PantherRacer wrote:beating a dead horse...
you asked for it
Nismo_Freak
PantherRacer wrote:awwwwwwwwwwww that's no fun ...............so, I wouldn't be able to say, beat slightly modded DET's unless I got either DET pistons or lower compression pistons designed for the DET? though I would be able to keep up?
You will make more power on less boost than a DET.
You should be able to run 10 PSI on a GOOD setup. That would net you 220 - 230whp and about 250wtq. That's plenty to punish regular DET's.
Nismo_Freak
Kushens and Panther, you need to clean up your sigs. They are too large.
MagikDragon
aww alright, will do. but only because you're making me.
Dori Dori
Car: Cars of course
No piston oil squirters on the de's though right?
PantherRacer
Darn....I thought my sig was hilarious...
Dori Dori wrote:No piston oil squirters on the de's though right?
ahhhh I think THAT'S the problem that was mentioned before....but that can be remedied or isn't really important?
Dori Dori
Car: Cars of course
It can be remedied by bringing the block to a machine shop and having the squirters machined in - or drill the block yourself!
Nismo_Freak
It's not really a big deal unless you are flogging the car for extended periods of time.
