Bingo. Stock Nissan cats tradistionally flow well so unless it's clogged, leave it alone, or replace it with a quality high flow one. Test pipes yield very minimal gains and just make your car sound worse.gabossie wrote:Resonator is for sound, and unless you are running a track car, don't take the cat out. I know I sound like a hippie, but they do good things for the environment, and removing it will yield VERY mild gains on a stock engine. When you go turbo, look into a high flow cat. You have to breath that **** just the same as the rest of us do.
