actually the intake manifold was MUCH easier for me. I was so amazed when I took it off because of that.NeedCAforS13 wrote:you guys try taking the intake manifold off in the car. grrr so many stupid little bolts and stuck coolant hoses. I had to do that yesterday, put it all back together and the brand new gasket was leaking coolant. so I got to do it again, but with lots of rtv on the gasket. stupid car.
translation: ratcheting wrenches with a pivotal head are the ballsfluent wrote:those 2 nuts were the worst.
If you have a ratchet spanner with flexi-head... makes life so much easier whilst removal!
haha shaddup. I have big hands. I'm going to use that as my excuse. but the second time was alot easier. I pulled the alternator so I could just reach all the bottom bolts from the front. 10000000x faster.dvd wrote:
Here's a set of ratcheting wrenches from home depot. I picked up a set of Gearwrenches from Sears for 80 bucks. Sounds kinda pricey but well worth the money.RalliartRsX wrote:Can anyone post pictures of what tools you used to remove them?? Also, C-rad, where'd you get your wratcheting swivel head?? I was thinking of picking up a set in the next few days.
I have the ssauto manifold. And to tell you the truth... it literally takes me 10 mins to get it off. Last two bolts on the end are still kind of pain, but I just reach my arm down there and throw the box end on it.RalliartRsX wrote:Hmmm, not bad. The problem I had with my ratchet head/open ended wrench was that the head was too big to fit in the space and slip over the bolt. If it was, man would it have saved me a bunch of time..........It seem to end up hitting the turbo (the two bolts under the mani closest to the firewall).
Did you have that problem anumeric or C-rad or anyone??
the answer is open ended ratcheting wrenches.... theyre made by 'all american' or something, you can pick them up at napa. PERFECT for the bolts you wouldnt be able to fit a normal racheting wrench, or a socket ontoRalliartRsX wrote:Hmmm, not bad. The problem I had with my ratchet head/open ended wrench was that the head was too big to fit in the space and slip over the bolt. If it was, man would it have saved me a bunch of time..........It seem to end up hitting the turbo (the two bolts under the mani closest to the firewall).
