taking off front bumper nissan logo
General discussion area for the L32-chassis Altima
herc0550
Car: 09 altima sedan (dark slate)
so i basically want to know how to take off the front nissan logo on the altima sedan 09 grill. is it clips? do i jus use a flathead or is it glued on? thanx. and once i take it off can i put it back on?? thank you.
ChinAltima08
Car: 2008 Nissan Altima 2.5 S+
malnevets
Car: 07 Altima Majestic Blue
herc0550 wrote:so i basically want to know how to take off the front nissan logo on the altima sedan 09 grill. is it clips? do i jus use a flathead or is it glued on? thanx. and once i take it off can i put it back on?? thank you.
you'll have to take off the grille, and then they're clips on the back that you release.
do not try to pry it off with a flathead from the front or the tabs will break and you'll have to use tape to put it back.
scrutmonkey
Car: 08 Altima Hybrid
It's pretty simple, you don't ahve to remove the grill.
1. pop Hood2. Pull up the hood realese lever and prop up hood.3. Pull up on the hood lever again and shove in arm.4. Now you can use your fingers to move the 4 clips. The left adn right clips are your main one.
i have a fat arm, so don't tell me you can't do it too :D
malnevets
scrutmonkey wrote:It's pretty simple, you don't ahve to remove the grill.
i guess i was making it harder then it really needed to be hahaa
scrutmonkey
Yeah, i found out you can do this about the 3rd time i took off my grill. Pretty simple, you just have to squeeze your arm in there a bit. same method as i would use to pop the clips for the lower part of the grill.
DjFuscious
Car: 2007 nissan altima 2.5s
i know someone that has a customized stock grill for the 08 coupe if anyone is interested
malnevets
DjFuscious wrote:i know someone that has a customized stock grill for the 08 coupe if anyone is interested
lol, how random
too bad this is the sedan section. if the grille was a custom sedan grille, then we porb. be more interested.
herc0550
thanx for the help. i did it already i blacked out the logo but i just purchased the mesh grill which should be coming in next week. ill post pics up of that.
Return to “4th Generation Altima Sedan (2007-2012)”
