Listen to this man! He is the definitive source on Z32 brake upgrade info!94_240sx wrote:They are not sealed. It's just aluminum color spray paint. I thinik they dremeled the surface smooth and that's why it looks like it's sealed. If you remove the 4 big bolts, you can take them apart. Those rubber seals and ring clips are aftermarket, and that's why they don't fit well. It's should be okay though. There's another seal in the middle of piston and it'll leak if that one is bad. Check out my write up for more detail.
http://www.nicoclub.com/articles.php?id=215854
Step on the caliper and use a breaker bar. It's not easy to remove those bolts.JerseyS14 wrote:i tried taking a bolt off (with tools but not an impact gun) but i couldn't get it to budge... seems like they're locktite'd in there for good..
These calipers are NOT monoblock. Monoblocks are made from a single piece of metal. A monoblock caliper does not have any bolts going from one side to the other besides the pad pin. Also, AZ doesn't cast these, they just take used calipers and send them off to get refurbished and then re-sell them.hilux30 wrote:thats right go return them and get original ones from a junkyard or online they are everywhere. I dont trust the casting, these are monoblock calipers which means under hard braking the caliper wants to spread and with cheap metal they can crack or totally break. I never saw it on Z32 calipers because I never dealt with this design from AZ, but casting strength and metarial is the most important part in the caliper not how many pistons.....
That is correct. How do you make those small channels where fluid goes through if it's mono black? That's impossible.killernoodle wrote:These calipers are NOT monoblock. Monoblocks are made from a single piece of metal. A monoblock caliper does not have any bolts going from one side to the other besides the pad pin. Also, AZ doesn't cast these, they just take used calipers and send them off to get refurbished and then re-sell them.
I agree. I also agree that you should just take some high temp paint to em. I did mine and it came out quite good. Long as you tape up the internals you should be fine.duffman1278 wrote: DO NOT SPLIT THESE CALIPERS APART!
Why not? i guess i can just high temp it if i find the color i'm looking for.. but why the "DO NOT SPLIT THESE CALIPERS APART!"... were they sealed during re-manufacturing... what's gonna happen.duffman1278 wrote: DO NOT SPLIT THESE CALIPERS APART!
why not?Chingon wrote:hell don't powdercoat them, also a bad idea.
It's because z32 factory service manual says so. Nissan doesn't sell small o-rings that go between two halves. You will have to reuse them or source exact same size o-rings. There's no torque spec for the 4 bolts that hold two pieces together. If you do it wrong, brake fluid will leak from the crack in the middle. I don't know. I ignored whatever z32 FSM said and powder coated mine and there's been no problem so far. No leaks or uneven wear of pads. Just be careful and rebuild them right and eveything should be okay. If I have to do it all over again, I'll still take them apart, rebuild and powder coat.JerseyS14 wrote:Yes please explain?
There are a lot of valid statements telling what to do but some don't tell me "why" to do or not do it?
