Takeda Short Air Intake
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
versaspeed.com
Car: Viper GTS & SRT10, Prowler, 300ZX TT, Versa SL 6mt, 240SX Race Car w/track records, Titan LE KC
Just got back from Takeda for a test fit of there Takeda Short Air Intake System and the Versa now has a Short Air System available for those looking in that direction.
Modified by versaspeed.com at 2:57 PM 3/10/2010
Promise Land
Car: 2011 Nissan Versa
2001 Chevy Suburban
1992 Ford Mustang
What are the advantages on the short ram air vs. the longer cold air intake?
superskunk
Car: '07 Nissan Versa S Hatch
'06 Nissan Murano SL
well if you were some how able to channel the air from grill to filter of the intake you could see some nice gains...
versaspeed.com
superskunk wrote:well if you were some how able to channel the air from grill to filter of the intake you could see some nice gains...
Here is the results of a Dyno run with the Cube which has the same Engine/Trans combinations.
Promise Land wrote:What are the advantages on the short ram air vs. the longer cold air intake?
If the Customer is afraid of sucking in water through the CAI which sits lower in the front fender.
So if you have the combination of the DC Cat-Back and the Takeda Short Air you would add around eleven pounds of tq and ten hp to a stock Versa.
superskunk
is this CARB legal or pending?
Codelicious
Car: 1989 Nissan 240SX
I might be interested in getting this pretty soon.. I was gonna get a Fujita but might as well try something new.
Wandr3r
Car: 2009 Versa SL
I just ordered this intake, there is no tangible hp gain from a cai, plus the added comfort in knowing you will not hydrolock your MR.
NCJack
Car: 2007 Versa SL
A CAI can be better performing because the air is coming in real low and far from the engine. This makes the intake air much cooler than the surrounding engine bay and as we all know, cooler air is more dense, denser air is more easily crammed into a cylinder and more air detected by the O2 sensor means more fuel = MORE POWER!
But, there is a con to CAI.....
HYDROLOCK
Serious damage can occur from a CAI if driving in very heavy rain or through deep puddles where as a Short Air Intake isnt prone to this because the intake is generally much higher and out of the way of possible water ingestion.
Even cavorting in puddles can causes splashes that can get sucked into the CAI causing damage
Of course, the SAI wont suck fresh cold air, but you dont run the risk of:
Both definatley increase airflow...your choice!
One more to scare you!
Regards,Jack
br4dysays
Car: 06 Nissan Altima SE-R
the hydro lock nonsense is overdone for the most part. unless you are driving through some monster puddles i don't think you'll be in much danger. its tucked away in the fender pretty well. just don't submerge your bumper in water...simple enough.
KGibbons
Car: 2008 nissan versa sport(canadian)
On my old nissan I dynoed a short ram and a cai, the short ram gave more power. it does suck warmer air but 2 feet less pipe and remeber one 90 degree bend is equal to 3 extra feet of pipe!
HTTP404
Car: Nissan Versa 2009 1.8 SL
I have installed the intake. Very nice.
Promise Land
2001 Chevy Suburban
1992 Ford Mustang
where did you buy it?
Any pics of it?
How easy was it to install?
HTTP404
Promise Land wrote:where did you buy it?
Any pics of it?
I bought it from versaspeed.The pics taken by my gf when I installed are not very clear. I will take some and upload.Since this SAI is designed for versa, it was very easy to install and the intake fits the space pretty well.
HTTP404
They Call Me Whatshisname
Car: 2006 Nissan 350Z
Will this fit on the 1.6L?
I want to know so bad. I was devastated when I found out the cai wouldn't fit =(.
Well I asked Bob from Versaspeed and he said it wouldn't because the rubber tube that goes from the intake to the airflow sensor assembly is larger on the 1.8l. So I ordered the AEM cold air intake because it uses the versa's tube so we'll see how that goes.
Ben_B
Car: 2008 Versa SL hatch.
I would also like to know if this is CARB certified? I would most likely buy one if it is.
Also, will it fit if you've got a front strut bar in there? Looks like it might be tight...
Promise Land
2001 Chevy Suburban
1992 Ford Mustang
CARB- no. Only AEM system is CARB certified.
Strut bar - yes.
Return to “Versa Technical Discussions”
