take the block out frome behind my gas
dezi
Car: 1992 nissan 240sx
will my car get more power if i take the block out from behind the gas peddle to open the thrittle body more and if it does is it really bad for it
Fenvy
Car: 2005 350Z Base 6MT
there is a block? anyways, your throttle body might be already opened all the way, to confirm, have a friend step on the gas peddle whiel you look at the position of the throttle body, there should be a notch on the TB for the valve to open any more than it can
1991S13
Car: '91 240sx Coupe, '00 QX4 4x4, '02 Sentra Spec V
The only thing I knew was behind the gas peddle is the kickdown switch (on AT cars).
Don't think you wanna go pulling that out, lol.
VitaminT
Car: 93 240sx SE
If you are talking about the little plastic lump under the accel. pedal....um no. Leave it and forget about it.
A while back I had it out for dying my carpet and A. there is a metal bracket under it that still causes a lump and B. the throttle body is already wide *** open before the pedal hits anything.
