sil240, virus77, and Hxc_nismo Thank you for answering some of my questions.
Sil240 wrote:Best thing to do is get a 20/25 pan and a 25 trans. Then since those stock t25/28s wont push 450 HP. Buy a good 26 single Manifold and a big single. Fab a down-pipe and follow up with supporting mods.
Stay LHD unless you like to torture yourself with the headache. With the single you will have more room.
As far as gauges go you have to get a ls auto tach. Or wire up the skyline cluster.
Yeah I have seen that the Lhd method is do able but I am super partial to having twin turbo setup. Still researching turbo options to eliminate as much turbo lag as possible. So having a rhd setup seemed nice but I run the risk of ordering a front clip that has a s***ty dash when I have worked so hard to take care of this one. I want to but I'm not sure.
HxC_Nismo wrote:just search just like the rest of us have, if you have a diagnostic issue go ahead and ask us but your like 2,378,967 Nico member asking us what you need or how to swap an rb into a s-chassis. I'm not trying to be an a s s but put yourself in our shoes and be asked the same question multiple times and it gets very old very quick.
I completely agree man. I'm not trying to be repetitive but it seems like the rb26 write up, the more detailed ones, are almost always a 25 or a 26 into an s13. I don't want to blow money by not being prepared and learning from every available source. thanks though man
virus77 wrote:s14 rpm gauge has enough adjustment with the POT in the back to read rpm correctly on an RB swap... I've setup working rpm gauges in 3 different s14's. S14 speedo also works perfect with the rb25det speed sensor.
I've got an ugly technique but I usually just screw with the adjustment pot and bounce the car off red-line in short bursts until it bounces at 7k. caveman like but its accurate
Wasn't aware that it red-lines at 7k. thank you that was another question I was thinking of buying an aftermarket s14 gauge if I couldn't find a nice R33 gauge.
Thanks guys keep 'em coming.
