so after debating for a long time and researcing about spending the extra cash for supertech dual springs or staying with the bc springs i already have. I came across this info that i got from the guys at brian crowers shop:The tech that works there said that he would recommend shimming the valve spring install height to 1.500” which would give you 105 lbs valve closed and 235 lbs valve open.
What are your guys thoughts on this? Sounds apealing to me. Supertech springs put like 116 lbs on the seat.
Postby
srdub-t »
https://forums.nicoclub.com/srdub-t-u52410.htmlWed Apr 02, 2008 10:05 am
hah yea but this is for a 500 hp build. Im using high lift cams 270 with 12.5 lift. Possibly revving to 9K so.... U guys think that the bc spring will do it with this shimming proccess
I run BC Springs (no shimming), Tomei 270 Solid Cams, and Tomei Solid Lifters and rev to 8500rpm without a problem. Ive hit 9300rpm in 1st gear not paying attention a handful of times.
