takaramotors wiring service
BeanerWolfe55
Car: 89 240sx
I Had them do my wiring i sent them all four of my harnesses both upper and lower ones they only wired the upper ones didn't even take the lower ones out of the box from what i was told they give you a plug and play harness idk if anyone else has had there wiring done by them but if so could you let me know
Thanks Justin
kamikazi
Car: 1989 240sx coupe sr20det
did you contact them about it?
BeanerWolfe55
Car: 89 240sx
yea i emailed them no response yet thougth i would ask you guys
NISMO_RB25
Car: 1992 240SX with RB25DET, 1987 RX-7 TII
wiring service is typically not for the lower harness, and actually i haven't seen anyone that does the lower harness as part of the service. There is a nice write up on how to do your lower harness yourself. The lower harness has your speed sensor, reverse light, 5th gear sensor, etc..It is easy to do.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
It is super easy to do. Just follow this guide from racebread's files section. It took me an hour and a half and that was the first time I've wired anything in my whole life. Should take someone who's done it before around 15-20 minutes.
http://www.racebread.com/Docum...o.doc
