Taka Turbo Lines
Morph
Car: 91 Sr Powered Coupe
Yo guys im just about to the end of my S14 turbo upgrade and im fixing leaks now i've should have fixed 2 but there is oil leaking out of the banjo bolt. My question is should there be a O ring or some thing like that on there b/c that bolt is tight as hell. Please guys any help is welcome i just want to start driving it now.
Ps i have a S13 Blacktop and i got the Taka Turbo lines from Phase 2 ( Which blow balls btw. )
wildacexxx
Car: 2002 Q45 nav sport
so taka lines suck?
teddy
Car: Saab Turbo and MR2
I had a set of takas on my s13 and they fit perfect and were nice. You should have some crush washers inbetween the banjo and bolt.
Morph
Nope what size
Nismo_180sx
Car: 1990 Nissan 240sx SE Redtop SR20DET with bolt-ons
I believe you can use the same copper bango gaskets used on the 300zx twin turbo shown here >>>> http://www.courtesyparts.com/z32/oe_turbo-hw.html
Just use the part number shown and order or check with your local Nissan dealer. Good luck!
VitaminT
Car: 93 240sx SE
I have used Taka clutch, brake, and turbo lines without ANY problems.
bgindn
Car: wieght lifting
hi
If you have a problem with the lines, you might want to send an email to me at [email protected].
New crush washers or teflon tape should do the trick perfectly.
harp
Morph
I got it on now i had to rethread the hole on the block and unscrewed the banjao fitting and added some locktight and it works fine now. What i mean about the lines being a pos is the fact that the lines dont fit. Now if the motor was out of the car would be the only way to put them on the way they were designed to. My water in hose was 2 in short and the water return hose required the y pipe to be bent away from the main, which is impossible while the motor is iniside the car.
Other than having to make a new hose they' re great.
PROJECTRB240SX
Car: 1972 DATSUN 240Z W/ SR20DET
DID YOU ORDER THE RIGHT LINES FOR YOUR APPLICATION?
BECAUSE SOME LINES ARE DESIGNED FOR THE S14 WATER OUTLET WITH THE WATER PORT ON IT.
t0mmych0
i agree that for the price, the lines where not all that.
karmakaze
Car: 98 240sx SE
QUOTE=t0mmych0]i agree that for the price, the lines where not all that.[/QUOTE]
i don't know what you guys are talking about.
i have taka lines in my s14 and they work great. and i had to install them with the engine in the car. it just requires some thought and planning when you tighten down the fittings in the turbo to get the right angles. you also need to have the arm for the inlet on the power steering pump from the sr20det. or it will sit against the taka fitting for your water inlet and your power steering pump belt still won't be tight enough. (you can swap out the arm, without removing the power steering pump from the car)
S13240
A while back my brother had to take his s13 to a local domestic shop to get his oil hole on the block rethreaded. The mechanic there saw the taka lines my brother had just bought and said that the taka lines are a very bad design. The mechanic called it, a temporary fix until your turbo blows from too much oil restriction.
I took his word for it just because he's had 30+ years in drag and nascar racing. He had lots and lots of damn trophies in his office.
