L Tankman »
https://forums.nicoclub.com/l-tankman-u233730.html
Thu Mar 27, 2014 4:52 pm
Well I've had this issue since I bought my 96 pathfinder a year ago. Got it for cheap due to a blown head on pass side, disassembled and sent heads out for machining, reassembled then sat for a month or two. Disassembled because cam seals were not put back in, then again due to suspicion of valve seals failing; possibly creating the smoke. At this point it has all new seals, resurfaced heads, and valve train should be spotless, new distributor, redone timing and I am almost to a point to giving up on it. Any ideas?
And note; compression test was solid, smoke looks like it's oil/coolant burning and smells overly fumey
