xdreamz »
https://forums.nicoclub.com/xdreamz-u10860.html
Sat Oct 25, 2003 5:59 pm
valve seals my new 91 project had the same prob at 200 thousand miles, now its got 30k,, you know what i mean,, any wan my 89 sohc did the same,at idle usually warm, the seals let a little oil throughand in the int and ex, the ex is ok but it burns and what not, and helps to clogg the rest of your exuast, but the int, goes in as a drop, sits on piston and soon as you hit bout 2k rpm its hot enough to burn it and ha,,,, smoke puff,, then all gone a while,,, anything else
