Taillights, running lights, cluster lights and blower fan dont work
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
brianzero
Car: 1986 Nissan 720 4x4 Regular Cab 265,000 mi! (Gasser unfortunately)
Hi All, I have seen various posts on the forums describing this problem, or something close to this problem. I have done damn near everything in my power to effect the problem. Ive cleaned all of the grounds, cleaned nearly all electrical connectors, replaced the rear lighting harness, changed the master lighting switch, changed the dimmer switch, changed all fuses...
Is there a relay that controls this lighting? Where do I find it if so?
PEZi
i do believe there is a relay... however... where its located i'm not sure
i'll need to check and see where... as well as if all the things are tied into it
dogred
Car: 1983 D720
Check the resistances of your fusible links. Low resistance is good, high is bad.
PEZi
ah yes... those stupid things
brianzero
Where are those fusible Links at? Usually their under the hood, but all I see are a few relays, which I replaced...
PEZi
directly off the pos batt terminal.... they're the mess of multi colored wires
brianzero
You mean that group of electrical connectors? Most are a spade style plug?
brianzero
And the relays? Does anyone know if a specific relays controls some of this stuff?
((BUMP))
PEZi
brianzero wrote:You mean that group of electrical connectors? Most are a spade style plug?
yes to the connector thing.... i don't know what style plug though
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
Yep, spade type lugs from the terminal to the wires.
brianzero
I check these fusible links, and they are good.
I am using 'Deoxit' on all of the connections. I have done the main connectors, fuse block, all relays, and now I am doing the subconnectors. No changes in the electrical system noted.
I just installed a new instrument cluster with a tach, and still no change.
Return to “Datsun 720”
