taillights and dashboard lights wont work
0range_Kouki24O
Car: s13 coupe and s14 sr20det w/2.3 stroker
headlights work now but my taillights will not turn on along with the lights on my dash. they use to work but i dont no what the problem is. im in my car trying to figure out the problem as im writing this so can someone help me please
borispuplis
check all the fuses under the dash, even under the hood. did u just put a radio in it... i had problems with previous owners hacking up the stock radio harness it would mess with the dash lights and clock and other things....
0range_Kouki24O
yes i checked all of my fuses under the steering wheel and under the hood everythin is fine. i dont have a radio unfortunatly my car was picked up in a junk yard and i built it from ground up so i couldnt afford a radio lol
jakesigs
Car: 240sx
How you doin Orange_kouki? Is your dash and tailights working now? Coz I just have the same problem like yours. Spend the whole day checking all the fuse boxes under the hood and the one by the clutch pedal. Lemme me know brow I have school on Tuesday night. Thanks!
chrisw777
Car: 94 nissan pathfinder
on my 94 pathfinder...what caused mine to do this was the light switchon the steering column. i fixed it by checking the contact inside the switch which is easy. either clean or bend the contact a little to make sure there is contact when you turn your lights on. anyway.....i think the dash and tail lights go thru that switch and its a place to look for where the problem might be.
0range_Kouki24O
i did that but i found the problem thanks for helping me out anyways. my wires were touching thus feeding my fuses too much power and causing it to blow.
JayNoel
Car: 90 RBZ32 rescue project
0range_Kouki24O wrote:i did that but i found the problem thanks for helping me out anyways. my wires were touching thus feeding my fuses too much power and causing it to blow.
where were your wires touching im having the same problem and i traced wires and cant find anything
