Taillight/illumination prob:
sr20671
Car: 89 nissan 240sx with a(n) ka24e engine Nismo r4 cam, injen intake, stage3 head obx headers Megan exhaust. Welded differential chrome polished valvecover
Okay here's the deal when I got my 40 the fuse for the taillights blew and melted the clips in the fuse block. so the previous owner took out the green wire in the back of the fuseblock and ran it through an inline fuse wire. But ran the other side of the inline fuse to a spare slot in the fuseblock.. So a month after I got the car the inline fuse wire blew and melted, so I replaced it with another inline fuse... Here's the deal..... I can on the car, on the lights,let it idle, or rev it high... It won't pop, if I drive it till 45-50 m.p.h. It won't pop but when I go to 60 m.p.h the fuse pops....everytime I've benn replacing about 15 fuses in a week this prob didn't happen before with the first inline fuse wire..... Need help please!!!!!!!!
Klits562
Car: white s13 coupe
im not an electrical wizz but i have been taught a little about it.
Try checking all of your grounds, it sounds like theres to much resistance in your elec system causing any current to take the path of least resistance which could be through your tail lights causing the fuse to blow.
I may be wrong but checking your grounds couldnt hurt any but could help solve your problem
sr20671
I recetly cheked that and the grounds were loose but it will still pop
shiro_neko
what mods do you have in this car that requires wiring? is it the green wire (meter & gauges) or green wire with red stripe (illumination)
sr20671
The green wire with red stripe,as for the mods with wiring I installed an aftermarket player, I ran the wiring seperately from the radio harness yet nothing happened for a month but even if it's not on it will pop I took out the faceplate or took out the player fuse it will pop
shiro_neko
does it pop with the light switch on or not? do you have a heads up display?
sr20671
Yeah it pops when the lights are on but only while I'm driving at 60 mph
sr20671
This is mostly a prob. With driving it at night everytime I'm at around 60 mph
shiro_neko
sorry been busy lately. I'll get back at you when I have the time. till then I think you should check your other fuses if they are within spec or not jumped.
sr20671
Ya I checked all the fuses and fusible links they're all fine, just the taillight fuse that keeps blowing out on me, I chechec the connections behind the fuse block, the timing control box grounds disconnected the player everything....
shiro_neko
the 15a fuse before the g/r wire is powered by the white wire.this white wire goes to accessory relays, other components such as horn, shift lock, timer control unit etc... it also connects to your 15a headlamp fuse. check this first because your popping the fuse when the lights are on.
your timing control unit ground is not connected?
sr20671
Found the prob finally, checked the ground for the box, good the prob was the signal light harness was spliced and all the wires we're touching the bumper support so I taped and insulated all the wires now I can go to 80 and haven't changed a fuse
