Tailgate wont lock!
Empty V
Car: 2001 Infiniti QX4
1982 Chevy Corvette C3 Shark
Well I was installing 2 more rear aux lights and went to open my tailgate and the alarm went off. My tailgate isn't responding to the keyless or the switches. I haven't taken it apart yet but wanted to see if anyone else has had this issue or might know what the possibilities are. TIA!
Billy
e2xx33
When you were installing the lights, perhaps a short/open circuit (depending on the door sensor switch) occurred in the rear hatch pressure switch. I know if the electrical system detects the rear hatch is open, it will not lock. I would check the wiring around the door pressure switch.
naladude911
Yea, my tailgate never locks
QX4ME
Car: 02 Infiniti QX4 4WD
11 MB C300 Sports
06 Honda Odyssey
e2xx33 wrote:...if the electrical system detects the rear hatch is open, it will not lock...
I tried leaving tailgate open, glass hatch open, and both open. In any case, if I use keyless control to lock, it will lock. When I leave only the glass hatch open and remote lock the doors, all door will lock but the alarm will not turn on until the hatch is closed. I can tell that from the alarm LED indicator.
Chuck Tribolet
Car: '01 Nissan Pathfinder
'87 Chevy Corvette
'01 Toyota Camry daily driver
'98 Boston Whaler Montauk
It's pretty easy to pull the interior panel and have a look at what's going on.
Chuck
Empty V
Chuck Tribolet wrote:It's pretty easy to pull the interior panel and have a look at what's going on.
Chuck
Yeah it is, I've done it a few times. Well after some discovery I've narrowed it down to the tailgate won't lock with the keyless but will unlock with it. I'm guessing it thinks the door is open. What is the pressure switch and where inside the panel is it located?
Thanks!
Billy
Chuck Tribolet
'87 Chevy Corvette
Does it lock both the rear side doors? If yes, it's not the back door switch becausethe two rear side door swtches and the back door switch are all wired in parallel.
Does it lock the RH rear side door, but not the LH rear side door and back door?The actuator for the LH rear side door and the actuator for the back door arewired in parallel.
The back door actuator doesn't have any special wiring for lock vs. unlock, soit's not a wiring problem.
I'd put a volt meter across the back door actuator and see if it[s pulsed whenyou send a lock signal. And also try just putting a finger on it (be careful)when sending a lock signal.
If you apply +12 to Pin 1 of the actuator, and ground to pin 2, it should lock.
See the FSM. On my '01 PF FSM, it's about page EL-250.
Happy Holidays!
Chuck Tribolet
'87 Chevy Corvette
Also, the '01 PF FSM doesn't say anything about sensing whether the backwindow is open.
CanuckQx4
Car: 2001.5 Infiniti QX4 2WD
Did you ever get this fixed empty??
Mine wont lock with the fob and my door open light is always on.
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
I found that the rubber cargo mat I have can prevent the door from locking if it's slid too far forward. Move it back and try again.
CanuckQx4
The door closes and I can lock it with my key in the hatch keyhole.
Problem is my fob doesnt affect the trunk lock/unlock and my car thinks the back door is always open...
Im assuming its electrical
ARKQX33V6
Check the relays in the engine bay for the alarm, then work towards the door.
CanuckQx4
I dont know how to "check" a relay or what you mean by work towards the door
