Postby
edogg27 »
https://forums.nicoclub.com/edogg27-u181559.htmlWed Jun 01, 2011 1:31 pm
i was wondering if any of u could shine some light on this problem.. one day i came out to my car and tried to open the glass on the tailgate and it wouldnt open.. i went around back and used the key and it works but the button doesn't..
Postby
ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.htmlFri Jun 03, 2011 6:03 am
Busted button, busted actuator, loss of ground, loss of + power, busted wire, busted or dirty connection.
Most likely a dirty fouled connection, but it will take an examination of the circuit. If you live in a hot, cold wet area the terminations wear just being there.
edogg27 wrote:well recently I had changed my rear wiper motor and when they took the motor off it worked but when they put the new one on it stopped again
My first reaction is to go back to whomever "they" is, and tell them to fix it.
well the shop that fixed the motor says they have no idea... but its not their fault it stopped working before they even did the motor.. but the minute they had the motor off i tried it and it worked
