centralcoaster33 »
https://forums.nicoclub.com/centralcoaster33-u27573.html
Mon Oct 09, 2017 1:44 pm
I read that if it's taped on (double sided foamy tape), then you can glide a string through there to cut it off (I've read that 50lb test fishing line works), then remove the adhesives. 3M makes an adhesive removal product that gets good reviews. 3M also has a wheel attachment for a drill that can buff that stuff off. For heat gun, you might consider heating the underside (from inside the trunk) to get closer to the glue than trying to heat the topside of the actual spoiler.
Good luck and let us know what works please for future people to find.
