Has anyone had problems with tailgate latches on 1st-gen Rogues?
In March 2013 the dealer replaced the latch assembly on my '10 Rogue under warranty. It generally still worked as a latch, except occasionally the door would need a harder slam to close, and the inbuilt sensor switch that triggers both the trunk light and dashboard 'door open' indicator only worked some of the time. A new latch fixed the problem, until a few days ago when I opened the tailgate and noticed the trunk light was again not working.
So I took the car in today to the friendly dealer. They determined that yet another latch is needed - it has been ordered and will be fitted f-o-c despite the car being well outside of warranty. Kudos to the dealer. But two latches going bad so far? In a car with less than 75,000km? Something's not right.
As an aside - maybe not an aside at all - I sometimes see a little puddle of water sitting in the small 'well' that surrounds the striker for the latch. It's very minor and I had assumed the water was getting past the door seal - too small to worry about. Now I'm theorizing that somehow I have water leaking inside the tailgate and trickling through the latch assembly, gradually causing it to gum up or corrode over time.
Would welcome any thoughts or suggestions!
