Tail lights wont work..have changed fuse-keeps blowing bulbs as wella
MrsSummerford
Car: 1996 Nissan 240 sx
Also, I have changed fuses and light bulbs for my taillights many times but the fuses keep blowing. Also my dashboard lights quit working after my taillights quit. (I'm guessing the problems are related).....I want to disconnect the battery cable and check to see if any wires are loose. Where can I find the wires for the taillights and the dashboard? How do I get to them?
s13_chris
Car: 90 240sx Hatch
If you would search. First thing, take out your CD player you probably recently wired in and wrap up ALL the wires. Make sure they are not showing. Come back once you have completed this task.
240sxFTW
Car: 89, 240sx coupe
Or if you recently unhooked a sub or a number of subs make sure you wrap the ends with electrical tape. And also do what that guy said ^
vLaDii
I just had the EXACT same problem after I installed my aftermarket CD player, the problem was there was a short in the wiring and it ended up being withing the CD player wiring. Dad did most the wiring work so I cant be more specific, sorry. Hope I helped a little though.
SirSilvia
Car: Sold both my babies
I'm going out to go test my driver side tail lights, I had to re-wire the white bulb holder since the wiring was hacked.here's what happens. all lights off-not pressing the brake: nothing, duh.pressing the brake: they all light up, but both bulbs on the driver side are dimmer than all the others.
parking lights/headlights are on-not pressing the brake: both tail lights on same brightness.pressing the brake: the driver side lights go completely out, the others are fine.
I've gotten pulled over twice in the last two weeks and I know they've been working great since I rewired them last fall. AND I installed my stereo about 4 years ago.I'm heading out right now with my multimeter to see what voltages I find or any other oddities.
SirSilvia
turns out its some effed up wires.I have the plastic shrouds taken out of the driver side of the trunk and I sometime carry my tool box. smashed the connector piece, so if i move it a certain way it works right. oh wellHEY!anybody got an extra bulb holder?
MrsSummerford
I do not have a CD player and I have not recently wired in anything or had it wired. How do I disconnect the battery so that I can safely checck the wiring??? and I know the wires are in the trunk and they are wrapped in electrical tape. How can I tell if there is a short in the wiring??Thank you!
maj Andres
Car: Zenki, '95 Model, w/ S14SR20DET
Damn! does everyone have this problem
zerothread?id=333617
zerothread?id=301547
zerothread?id=415378
xX RB Xx
Car: SE3P, FC3S, FC3C.
i just fixed the same problem on a friends car..
try a 25 amp fuse.. that is what we used.
zerepdivad
Car: '90 240sx . '02 Lexus IS300
xX RB Xx wrote:i just fixed the same problem on a friends car..
Man that is not only a very stupid thing to do it's really unsafe! I've seen stuff start on fire from people doing crap like that. Fix things the proper way or send it to someone who know's what they're doing.
maj Andres
What he said. I'm pretty sure Nissan used a 10a fuse for a reason.... like not to blow up any circuits!
xX RB Xx
it was his idea.. i fixed the problem with tail lights staying on all the time..
so i take half the blame.
