Tail lights wont go off
joshezzy
Car: 1989 nissan 240sx
Why would my tail lights not go off even with the car off, the key out of the egnition, and all doors closed?
Razi
Car: Moo
Did you turn it off at the stalk?
TroubleBound
Car: 1992 240SX Hatch
i bet its the switch over the brake pedal mine is loose sometimes
joshezzy
yea i made sure i turned the lights off. whats the switch over the brake pedal?
Razi
Car: Moo
It's the switch that is pressed when you hit the brakes, it's what turns on the taillights.
It'd be a good idea to get under there and check it out.
joshezzy
is it located under the car or inside
Razi
Car: Moo
At your brake pedal.
Inside the car.
Dattebayo
Stick your head down where the pedals are and look up under the dash. ON top of the brake pedal's shaft there is a switch.
You should know that you are in the wrong forum.
dusred
Car: Previous Q45 owner, 09 Corolla, Ford F250 Diesel truck
Did you try letting off the brake pedal? Just sayin. . .
Razi
Car: Moo
I'm pretty sure he's done that, dusred.
Unless he only checks out his taillights while inside the car...with his foot on the pedal... :gotme
dusred
Since I couldn't contribute to the thread in a productive way I just decided to throw my .02 in. :poke: Sry if it wasn't clear. :poke:
costa_rican13
Car: 1993 s13 coupe
dusred wrote:Did you try letting off the brake pedal? Just sayin. . .
:lolling: i was thinking the same thing!!!! XD
Papi Chulo
Car: 72' Datsun 510
Maybe you have parked in a manner which has the rear portion of your vehicle facing the sun creating the illusion that your lights are illuminated, in actuality they aren't.
Dittoz7
Car: 1997 2f0WtY SE!
Little rubber stop prob failed. Just go to any auto store and those plastic interior clips and plug it.
TroubleBound
joshezzy wrote:yea i made sure i turned the lights off. whats the switch over the brake pedal?
Yeah its a button over top of your brake pedal. When you let go of the pedal it presses the button and turns the lights off. If it came loose than your pedal may not be pushing it down all the way anymore. Mine is so old the button actually chewed a hole straight through my pedal and they were on for a week until i put a thick magnet over the hole that presses the button now while im off the pedal. Just look at the top of your brake pedal and push the little black button and have someone tell you if they go off. It's like a 10 min fix if thats your problem, just one wrench.
uber240times2
Car: 1989 240sx hatch
2003 350z
Same thing just happened recently to me. There's a little push on the pedal, and there's a stop mounted in the car and when the button is pushed it turns the lights off. If the stop fell out then you're lights will stay on. Good luck.
