Tail Lights
enriquerrs
Car: 2000 Pathfinder SE
Hi, I'm new here I have a 2000 Pathfinder SE with 141,000 miles, I'm looking to change the tail lights does the QX4 tail lights fits the Pathfinder?
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
As far as I know they will fit, but the problem is that reverse lights are in the hatch on QX4s and there may not be a spot to place the reverse lights if QX4 tails are used on a Pathfinder.
Welcome to NICO.
enriquerrs
Thanks I didn't thought on that
Zymol75
Car: R50 Pathfinder Q swapped
The 99 QX4 tails have the reverse in them. I did a full swap on all the lights on my Pathy and a donor Q and the tails part required I take the pigtails from the Q and cut/splice/replace them into the harnesses in the Pathy lamp buckets. The difference is the Q lamps are Red/White only and the Pathy lamps are Red/White/Yellow, and the order of the bulbs top to bottom is different. The wire colors are all identical and it's as easy as matching colors. If you go newer like to a 01 & 02 and such then the reverse lamps move to the deck by the plate.
enriquerrs
Thanks I'm planning to stay with the stock ones and buy them some grill covers
